TDK Life on Record A26 Front Faceplate Replacement
  1. TDK Life on Record A26 Front Faceplate Replacement, Front Faceplate: step 1, image 1 of 2 TDK Life on Record A26 Front Faceplate Replacement, Front Faceplate: step 1, image 2 of 2
    • Obtain the black plastic spudger to remove the faceplate.
    • Insert the pointed end of the tool inside one of the holes on the faceplate itself.
    • The corner is the best place to start.
    • The faceplate has many little holes so choose one that makes it easier for you.
  2. TDK Life on Record A26 Front Faceplate Replacement: step 2, image 1 of 3 TDK Life on Record A26 Front Faceplate Replacement: step 2, image 2 of 3 TDK Life on Record A26 Front Faceplate Replacement: step 2, image 3 of 3
    • Gently start to lift until the faceplate starts to rise.
    • If you are having trouble getting the faceplate off, continue trying on the rest of the corners until fully removed.
4 other people completed this guide.
Elise Howard
831 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 482
