TDK Life on Record A33 AC Adapter Prongs Replacement
  1. TDK Life on Record A33 AC Adapter Prongs Replacement, Prongs: step 1, image 1 of 1
    • Locate the small hole, which is in the shape of a semicircle. It is below the plastic piece that has the prongs attached.
  2. TDK Life on Record A33 AC Adapter Prongs Replacement: step 2, image 1 of 2 TDK Life on Record A33 AC Adapter Prongs Replacement: step 2, image 2 of 2
    • Push the button that is inside the hole with the metal spudger and hold it down.
    • While the button is being pressed, push up on the prongs with your thumb. If the prongs aren't moving, you might need to push down a little harder on the button.
    • The button does not need to be pressed when sliding the prongs back in.
  3. TDK Life on Record A33 AC Adapter Prongs Replacement: step 3, image 1 of 1
    • Remove the prongs from the AC Adapter. Any repairs on the prongs can now be easily done.
Matthew Festa
808 Reputation
3 Guides authored
UMass Dartmouth, Team 4-2, Catania Fall 2015 Member of UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 2,621
