TI-36X Pro Battery Replacement
Robert Sekerak
Robert Sekerak and 8 other contributors
Last updated on March 8, 2023
5 - 10 minutes
Easy
Introduction
Go to step 1
For this guide you will remove the back cover and battery cover in order to replace the battery.
Parts
Tools
Show more…
  1. TI-36X Pro Battery Replacement, Back Cover: step 1, image 1 of 2 TI-36X Pro Battery Replacement, Back Cover: step 1, image 2 of 2
    • Remove the calculator's protective cover.
    • Place the calculator face down.
  2. TI-36X Pro Battery Replacement: step 2, image 1 of 2 TI-36X Pro Battery Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
    • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
  3. TI-36X Pro Battery Replacement, Battery: step 3, image 1 of 2 TI-36X Pro Battery Replacement, Battery: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
    • Remove the battery cover without disconnecting either end of the blue wire.
    • Use your finger to move the battery cover to the side.
  4. TI-36X Pro Battery Replacement: step 4, image 1 of 1
    • Use the flat side of a spudger to remove the battery by lifting the bottom edge.
    • When inserting a new battery, check the polarity (+ or -) and insert the new battery with the + side on top.
11 other people completed this guide.
Robert Sekerak
664 Reputation
4 Guides authored
Cal Poly, Team 11-52, Amido Spring 2014 Member of Cal Poly, Team 11-52, Amido Spring 2014
CPSU-AMIDO-S14S11G52
4 Members
10 Guides authored
5 Comments
Interesting that the cr2032 battery is not rechargeable, so is the solar panel real? Or does it bypass the battery and use the solar panel in lighted situations?
frogman896 - Reply
The guide should specify that the CR2032 needs to be rechargeable. They are readily available at a popular online shopping website. I was skeptical that the solar was real too, because of the frosted plastic placed over it. Based on the pictures in this teardown, and another video showing a red LED in the solar circuit, I conclude that the solar charging circuit is real.
Jacob Ertel -
The manual doesn't specify a rechargeable battery. It just says a CR2032 Lithium battery. Unless all such batteries are rechargeable? I guess I'll find out since I just replaced the battery in mine and it's an Energizer CR2032, but it doesn't appear to say rechargeable anywhere on the packaging or the battery itself. I guess if it kills my calculator, it had a good run....
EDIT: The original battery that I took out of the calculator doesn't say rechargeable on it either.
Marc W - Reply
good guide, I'd just like to add that in my case I needed to press the "Reset" button for my calculator to start up again
Greg B - Reply
yeah but I have done that 3 times and now my calculator is officially announced dead....
Danielle Kennedy -
Past 24 Hours: 4
Past 7 Days: 54
Past 30 Days: 206
All Time: 33,511
