TI-84 Plus Disassembly
  1. TI-84 Plus Disassembly, flip: step 1, image 1 of 2 TI-84 Plus Disassembly, flip: step 1, image 2 of 2
    • Be sure the calculator is powered off before proceeding.
    • Take off the sliding cover, and flip your calculator to the back side.
  2. TI-84 Plus Disassembly, battery plate.: step 2, image 1 of 2 TI-84 Plus Disassembly, battery plate.: step 2, image 2 of 2
    • Press down on the latch, then remove the battery cover.
  3. TI-84 Plus Disassembly, take out the batteries: step 3, image 1 of 2 TI-84 Plus Disassembly, take out the batteries: step 3, image 2 of 2
    • Remove the batteries.
    • You can use the battery cover as a plate to keep the batteries.
  4. TI-84 Plus Disassembly, back up battery: step 4, image 1 of 3 TI-84 Plus Disassembly, back up battery: step 4, image 2 of 3 TI-84 Plus Disassembly, back up battery: step 4, image 3 of 3
    • Removing this battery will clear your RAM, so be sure that you have made any backups of important data.
    • Use a Phillips #0 to remove the plate from the back up battery.
  5. TI-84 Plus Disassembly, backup battery: step 5, image 1 of 2 TI-84 Plus Disassembly, backup battery: step 5, image 2 of 2
    • Remove the backup battery with either a screwdriver or the spudger.
  6. TI-84 Plus Disassembly, Remove the back cover: step 6, image 1 of 1
    • Use a T6 Torx screwdriver to remove the six screws securing the back cover.
  7. TI-84 Plus Disassembly, cracking the case: step 7, image 1 of 3 TI-84 Plus Disassembly, cracking the case: step 7, image 2 of 3 TI-84 Plus Disassembly, cracking the case: step 7, image 3 of 3
    • Use a prying tool to get a pick into the side and then move it down until it's open.
11 other people completed this guide.
martijn muntenaar
756 Reputation
1 Guide authored
1 Guide Comment
Nice! My calculator wasn't turning on, took it apart and rebent the contacts for the batteries, works great now!
Noah Molla - Reply
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 111
All Time: 12,632
