TMY V08 Lens Replacement
  1. TMY V08 Lens Replacement, Top Panel: step 1, image 1 of 3 TMY V08 Lens Replacement, Top Panel: step 1, image 2 of 3 TMY V08 Lens Replacement, Top Panel: step 1, image 3 of 3
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
  2. TMY V08 Lens Replacement: step 2, image 1 of 3 TMY V08 Lens Replacement: step 2, image 2 of 3 TMY V08 Lens Replacement: step 2, image 3 of 3
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
  3. TMY V08 Lens Replacement, Lens: step 3, image 1 of 3 TMY V08 Lens Replacement, Lens: step 3, image 2 of 3 TMY V08 Lens Replacement, Lens: step 3, image 3 of 3
    • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Pull back the motherboard to expose the connectors underneath.
  4. TMY V08 Lens Replacement: step 4, image 1 of 2 TMY V08 Lens Replacement: step 4, image 2 of 2
    • Rotate the projector counterclockwise 90 degrees.
    • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
  5. TMY V08 Lens Replacement: step 5, image 1 of 3 TMY V08 Lens Replacement: step 5, image 2 of 3 TMY V08 Lens Replacement: step 5, image 3 of 3
    • Rotate the projector counter clockwise with the front facing you.
    • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
    • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
  6. TMY V08 Lens Replacement: step 6, image 1 of 2 TMY V08 Lens Replacement: step 6, image 2 of 2
    • Flip the projector over so the bottom is facing up.
    • Remove the two 13.9 mm screws using a Phillips #1 screwdriver.
  7. TMY V08 Lens Replacement: step 7, image 1 of 2 TMY V08 Lens Replacement: step 7, image 2 of 2
    • Flip the projector back over.
    • Remove the fine gauge adjustment, by lifting it out.
  8. TMY V08 Lens Replacement: step 8, image 1 of 3 TMY V08 Lens Replacement: step 8, image 2 of 3 TMY V08 Lens Replacement: step 8, image 3 of 3
    • Grasp the side of the lens.
    • Pull the lens outward away from the hole while pulling upward to remove the lens.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 49
All Time: 1,077
