TP-Link HS110 Disassembly
  1. TP-Link HS110 Disassembly, TP-Link HS110 Disassembly: step 1, image 1 of 1
    • Keep in mind, that following this guide will void your warranty! Even the first step!
  2. TP-Link HS110 Disassembly: step 2, image 1 of 2 TP-Link HS110 Disassembly: step 2, image 2 of 2
    • There is 1 screw that holds the cover plate in place. In order to open the housing you have to remove that screw.
    • The screw is hiding under the sticker. You can try to remove the whole sticker. I just scratched through with the spudger to expose the screw. (This voids your warranty!)
    • Remove the screw. I used a PH0 screw bit.
  3. TP-Link HS110 Disassembly: step 3, image 1 of 3 TP-Link HS110 Disassembly: step 3, image 2 of 3 TP-Link HS110 Disassembly: step 3, image 3 of 3
    • To remove the cover plate I used the metal spudger.
    • Start on the bottom of the plate. There is a little gap right above the Reset Connection button. The spudger fits perfectly in that little gap and you can pop the first clamps out by stretching it.
    • I think this was the key for the whole process.
    • After that, just go around with the spudger and pop all the clamps out one by one.
  4. TP-Link HS110 Disassembly: step 4, image 1 of 1
    • The hardest part is over. Congratulations!
  5. TP-Link HS110 Disassembly: step 5, image 1 of 3 TP-Link HS110 Disassembly: step 5, image 2 of 3 TP-Link HS110 Disassembly: step 5, image 3 of 3
    • Finally, the internals are exposed. But be careful, it is very easy to break the whole circuitry!
    • There are 2 main PCBs inside on top of each other. Those are connected via a soldered mini "bus" PCB. The bottom one is screwed into the backplate via 2 little screws. You have to remove those to get the whole thing out without breaking it.
    • Unfortunately, the screwdriver in the Pro Tech Tool Kit did not fit into the small gap which leads to the screws. So I had to improvise with a small form factor screwdriver from a random HDD kit.
  6. TP-Link HS110 Disassembly: step 6, image 1 of 2 TP-Link HS110 Disassembly: step 6, image 2 of 2
    • After removing the 2 little screws, you can pop the whole thing out from the housing.
    • If your device has the same malfunction as mine and you managed to fix it, please reach out to me, so I can have my smart plug back in business! Thanks!
2 other people completed this guide.
Benedek Petrovicz
178 Reputation
1 Guide authored
2 Guide Comments
To repair the device, you must replace the capacitor C4 = 470 mf 16V that you see on the back of the the red arrow on step 5.
If you check, it have a bulge on the top, on my device happened the same, now it works.
Mauro Ferrigioni - Reply
Hello, I also have a problem with this equipment. Unlike you, I have a good WIFI connection and it doesn't switch off unexpectedly. However, when I press the switch or turn it off via the app, the power still flows. I think it could be the relay but I'm not sure. Do you think this could be the cause? How can I test it? Thanks
Benoit Rigal - Reply
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 53
All Time: 1,201
