TYLT VU Wireless charging car mount Disassembly
  1. TYLT VU Wireless charging car mount Disassembly, Removing the front panel: step 1, image 1 of 2 TYLT VU Wireless charging car mount Disassembly, Removing the front panel: step 1, image 2 of 2
    • First thing you want to do is lift up the corners of the rubber mat that makes up the center that your phone sits on. Here you will find 4 screws (One in each corner). Remove these screws and the whole front panel should come off.
  2. TYLT VU Wireless charging car mount Disassembly, Disconnecting the front panel: step 2, image 1 of 1
    • Next you need to be careful not to brake any of the 3 wires running from the main charging circuit to the power intake port, that sits on a seperate chip in the bottom housing. This is held on by 1 screw.
  3. TYLT VU Wireless charging car mount Disassembly: step 3, image 1 of 3 TYLT VU Wireless charging car mount Disassembly: step 3, image 2 of 3 TYLT VU Wireless charging car mount Disassembly: step 3, image 3 of 3
    • Now your should be left with this bottom part. To get to the sprockets and the locking mechanism inside, you need to remove the plate that is secured with 4 screws + 1 smaller screw. When that plate is removed (might take some slight convincing) you will see the sprockets and mechanism seen in picture 2 and 3.
  4. TYLT VU Wireless charging car mount Disassembly: step 4, image 1 of 1
    • Mind the small spring in picture 1 when assembling, this pulls both the clamps out when the button is pushed. Also remember to realign all the parts when assembling. Other than that it is the reverse of dissasembling.
Sebastian van Veen
271 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,069
