Table Fan Blades Replacement
  1. Table Fan Blades Replacement, Blades: step 1, image 1 of 3 Table Fan Blades Replacement, Blades: step 1, image 2 of 3 Table Fan Blades Replacement, Blades: step 1, image 3 of 3
    • Use a prying tool to loosen the front cover.
    • After it is pried loose, remove the cover.
  2. Table Fan Blades Replacement: step 2, image 1 of 1
    • Remove two 12.7 mm Phillips #2 screws from the back cover.
    • Take off the back cover.
  3. Table Fan Blades Replacement: step 3, image 1 of 1
    • Remove two 38.1 mm Phillips #2 screws from the motor.
  4. Table Fan Blades Replacement: step 4, image 1 of 3 Table Fan Blades Replacement: step 4, image 2 of 3 Table Fan Blades Replacement: step 4, image 3 of 3
    • While holding the back of the fan, pull the blades.
    • Take off the old blades and put them aside.
  5. Table Fan Blades Replacement: step 5, image 1 of 1
    • Take the motor out.
  6. Table Fan Blades Replacement: step 6, image 1 of 2 Table Fan Blades Replacement: step 6, image 2 of 2
    • Clean all parts of the fan.
  7. Table Fan Blades Replacement: step 7, image 1 of 2 Table Fan Blades Replacement: step 7, image 2 of 2
    • Put the motor and back cover back on.
    • This can be done by following steps 2, 3, and 5 in reverse.
  8. Table Fan Blades Replacement: step 8, image 1 of 1
    • Place the new blade onto the metal rod on the front of the fan.
    • Push the blades onto the rod so that it is sturdy.
    • Replace the front cover.
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 2,275
