Tagital T10 Speaker Replacement
  1. Tagital T10 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Always make sure your device is completely powered off before performing repairs.
    • Remove the two 4mm screws at the top of the device.
  2. Tagital T10 Speaker Replacement: step 2, image 1 of 2 Tagital T10 Speaker Replacement: step 2, image 2 of 2
    • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
    • Set the back cover aside.
    • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Carefully set the back cover aside so that you do not rip the wires free.
  3. Tagital T10 Speaker Replacement: step 3, image 1 of 3 Tagital T10 Speaker Replacement: step 3, image 2 of 3 Tagital T10 Speaker Replacement: step 3, image 3 of 3
    • Locate where the speaker's wires connect to the motherboard.
    • Heat the solder to soften it and disconnect the wires using the soldering tool.
  4. Tagital T10 Speaker Replacement: step 4, image 1 of 2 Tagital T10 Speaker Replacement: step 4, image 2 of 2
    • Remove the old speakers from the back cover with the plastic prying tool.
Cody D'Amato
303 Reputation
2 Guides authored
USF Tampa, Team 14-5, Eyestone Fall 2016 Member of USF Tampa, Team 14-5, Eyestone Fall 2016
USFT-EYESTONE-F16S14G5
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 223
