Tagital T7X Camera Replacement
  1. Tagital T7X Camera  Replacement, Case: step 1, image 1 of 3 Tagital T7X Camera  Replacement, Case: step 1, image 2 of 3 Tagital T7X Camera  Replacement, Case: step 1, image 3 of 3
    • Place the Tagital T7X on a sturdy surface.
    • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
  2. Tagital T7X Camera  Replacement, Camera: step 2, image 1 of 3 Tagital T7X Camera  Replacement, Camera: step 2, image 2 of 3 Tagital T7X Camera  Replacement, Camera: step 2, image 3 of 3
    • Use a spudger to hold the cameras in place.
    • Gently pull the black tape away using your finger.
  3. Tagital T7X Camera  Replacement: step 3, image 1 of 3 Tagital T7X Camera  Replacement: step 3, image 2 of 3 Tagital T7X Camera  Replacement: step 3, image 3 of 3
    • Remove the ribbon cable from the motherboard.
    • Use a spudger to lift the two tabs, freeing the ribbon cable from the socket.
  4. Tagital T7X Camera  Replacement: step 4, image 1 of 3 Tagital T7X Camera  Replacement: step 4, image 2 of 3 Tagital T7X Camera  Replacement: step 4, image 3 of 3
    • Gently pull the ribbon cable away from the motherboard.
    • Don't be afraid to use some force to pull the ribbon cable.
Hanlong Chen
265 Reputation
2 Guides authored
USF Tampa, Team 2-1, Sullivan Spring 2016 Member of USF Tampa, Team 2-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G1
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 184
