Tagital T9X Volume, power, or return button Replacement
  1. Tagital T9X Volume, power, or return button Replacement, Back Cover: step 1, image 1 of 1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Volume, power, or return button Replacement: step 2, image 1 of 1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Volume, power, or return button Replacement, Volume, power, or return button: step 3, image 1 of 1
    • Remove the broken volume button from the plastic case. Replace it with the new volume button, with the + being closer to the camera opening.
    • There are two other small buttons that look very similar to one another; if they fall off as well, put them back in their rightful place.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 276
