Tapwave T2907US Zodiac 2 Battery Replacement
  1. Tapwave T2907US Zodiac 2 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Battery Replacement: step 2, image 1 of 1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Battery Replacement, Battery: step 3, image 1 of 1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Battery Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
Finish Line
2 other people completed this guide.
Daniel Wiseman
133 Reputation
6 Guides authored
Cal Poly, Team 10-33, Amido Winter 2012 Member of Cal Poly, Team 10-33, Amido Winter 2012
CPSU-AMIDO-W12S10G33
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 1,254
