Tatung TAC-6G Heating Element Replacement
  1. Tatung TAC-6G Heating Element Replacement, Heating Element: step 1, image 1 of 1
    • Lift the lid and bowl from top of the device
    • Be sure device is not plugged in before beginning replacement of heating element
  2. Tatung TAC-6G Heating Element Replacement: step 2, image 1 of 1
    • Turn the bowl upside down so that the three legs point upwards
  3. Tatung TAC-6G Heating Element Replacement: step 3, image 1 of 2 Tatung TAC-6G Heating Element Replacement: step 3, image 2 of 2
    • Remove the one 7 mm Phillips screw from the side of the brass panel.
  4. Tatung TAC-6G Heating Element Replacement: step 4, image 1 of 2 Tatung TAC-6G Heating Element Replacement: step 4, image 2 of 2
    • Remove the 6mm Phillips screw that holds the stainless plate.
  5. Tatung TAC-6G Heating Element Replacement: step 5, image 1 of 3 Tatung TAC-6G Heating Element Replacement: step 5, image 2 of 3 Tatung TAC-6G Heating Element Replacement: step 5, image 3 of 3
    • Remove all four of the 15mm Phillips screws from all four of the brackets that hold the heating element in place
  6. Tatung TAC-6G Heating Element Replacement: step 6, image 1 of 1
    • Using your hands, remove the heating plate that is on top of heating element.
  7. Tatung TAC-6G Heating Element Replacement: step 7, image 1 of 1
    • Remove the 7mm Phillips screw that holds the white wire connected to the heating element.
  8. Tatung TAC-6G Heating Element Replacement: step 8, image 1 of 1
    • Remove the 7mm Phillips screw that holds the white & maroon wires connected to the heating element.
  9. Tatung TAC-6G Heating Element Replacement: step 9, image 1 of 1
    • Using, your hands, take out the heating element and replace it with a new one.
6 Comments
where can I buy this heating element? Thanks.
dchang168 - Reply
Tze Moh Yeo - Reply
where to buy parts is the problem!!
William Co - Reply
not sell tools here but parts, it’s easy to repair but parts is the problem
William Co - Reply
heat elements can be purchased in Taiwan. if you can read Chinese.
chengshiuntsai - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 39
All Time: 4,175
