Remove the screw with Phillips screwdriver.
Pull the metal lever upwards to pull it off
Remove the water tank and the attachments (drip pans, etc.)
Remove all the water from the machine
Remove the screws on the back (behind the water tank) with the tensioner 2.0 bit or a screwdriver
Remove the screw in the lid with a Phillips screwdriver
Run a spudger around the lid to loosen the clips.
Carefully lift off the lid (cable control unit!)
remove the 2 screws with a Phillips screwdriver
Remove the right side panel
Work through the steps in reverse order to reassemble your device.
5 other people completed this guide.
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
