Tea Kettle Switch Replacement
  1. Tea Kettle Switch Replacement, Switch: step 1, image 1 of 3 Tea Kettle Switch Replacement, Switch: step 1, image 2 of 3 Tea Kettle Switch Replacement, Switch: step 1, image 3 of 3
    • Before you start, disconnect the device from its power source.
    • Remove the two bottom screws.
    • Remove the two top screws.
    • Remove the handle from the kettle.
  2. Tea Kettle Switch Replacement: step 2, image 1 of 2 Tea Kettle Switch Replacement: step 2, image 2 of 2
    • Pull out the switch.
    • If you pull too hard, you may dislodge another part as well as the spring that are both positioned behind the switch.
  3. Tea Kettle Switch Replacement: step 3, image 1 of 1
    • Click the replacement switch back into the handle part.
  4. Tea Kettle Switch Replacement: step 4, image 1 of 1
    • Insert the light back into the switch.
    • This might take some extra attention, so be precise.
  5. Tea Kettle Switch Replacement: step 5, image 1 of 1
    • Place the handle part back on the frame.
  6. Tea Kettle Switch Replacement: step 6, image 1 of 1
    • Plug in the kettle.
    • Press down on the switch to check if it works again.
6 other people completed this guide.
3 Guide Comments
How much would it cost to repair this kettle switch live points?
Bheki Valoyi - Reply
How much would it cost to fix the tea kettle switch live points?
Can the kettle gadgets be replaced with another one
Michael Ombech - Reply
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 131
All Time: 26,862
