Technique - Test the Battery
  1. Technique - Test the Battery, Technique - Test the Battery: step 1, image 1 of 3 Technique - Test the Battery, Technique - Test the Battery: step 1, image 2 of 3 Technique - Test the Battery, Technique - Test the Battery: step 1, image 3 of 3
    • Remove back cover by applying pressure and sliding up towards the top of the phone.
  2. Technique - Test the Battery: step 2, image 1 of 2 Technique - Test the Battery: step 2, image 2 of 2
    • Remove the battery by lifting from slot on the right hand side.
  3. Technique - Test the Battery: step 3, image 1 of 2 Technique - Test the Battery: step 3, image 2 of 2
    • Use Multimeter to test the voltage of the battery.
    • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
    • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
Melinda Phan
438 Reputation
9 Guides authored
Cal Poly, Team 9-64, Walters Spring 2011 Member of Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Members
18 Guides authored
2 Guide Comments
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
Roger Slater - Reply
yes,not tablet with battery removal difficult
paulbeames7 - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 40
All Time: 10,782
