Technostar Sandwich Toaster Thermal Fuse Replacement
  1. Technostar Sandwich Toaster Thermal Fuse Replacement, Thermal Fuse: step 1, image 1 of 1
    • Open the toaster.
    • Remove the four screws which attach the mold.
  2. Technostar Sandwich Toaster Thermal Fuse Replacement: step 2, image 1 of 2 Technostar Sandwich Toaster Thermal Fuse Replacement: step 2, image 2 of 2
    • Remove the mold to get access to the heating coil.
  3. Technostar Sandwich Toaster Thermal Fuse Replacement: step 3, image 1 of 1
    • Find the thermofuse.
  4. Technostar Sandwich Toaster Thermal Fuse Replacement: step 4, image 1 of 2 Technostar Sandwich Toaster Thermal Fuse Replacement: step 4, image 2 of 2
    • Cut the two wires that connect to the thermal fuse.
  5. Technostar Sandwich Toaster Thermal Fuse Replacement: step 5, image 1 of 2 Technostar Sandwich Toaster Thermal Fuse Replacement: step 5, image 2 of 2
    • Align the thermal fuse with the open wires.
    • Put the spade connectors over the wires.
    • Using pliers, clamp the wires together.
  6. Technostar Sandwich Toaster Thermal Fuse Replacement: step 6, image 1 of 1
    • Replace the molds.
    • Replace the four screws which attach the mold.
Finish Line
4 other people completed this guide.
2 Comments
where did u find the replacement fuse? I need a thermal fuse for Breville BSG520XL Panini Duo Grill
mortaz - Reply
how do i test that the reason that my toaster is not working is actually the thermal fuse?
itzsabag - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 4,074
