Teddy Bear Nose Replacement
  1. Teddy Bear Nose Replacement, Nose: step 1, image 1 of 2 Teddy Bear Nose Replacement, Nose: step 1, image 2 of 2
    • Rip out about five inches of stitches from around the bear's snout.
  2. Teddy Bear Nose Replacement: step 2, image 1 of 2 Teddy Bear Nose Replacement: step 2, image 2 of 2
    • Remove stuffing from around the bear's snout.
  3. Teddy Bear Nose Replacement: step 3, image 1 of 1
    • Flip the fabric of the snout inside out to expose the back of the plastic nose.
  4. Teddy Bear Nose Replacement: step 4, image 1 of 2 Teddy Bear Nose Replacement: step 4, image 2 of 2
    • Remove the plastic backing of the teddy bear's nose (if it's still there). You may have to use pliers.
  5. Teddy Bear Nose Replacement: step 5, image 1 of 1
    • Pull the nose out of the front of the teddy bear’s face.
  6. Teddy Bear Nose Replacement: step 6, image 1 of 1
    • Push the front of the new nose through the existing hole in the teddy bear’s face.
  7. Teddy Bear Nose Replacement: step 7, image 1 of 1
    • Attach the nose backing on the inside of the teddy bear’s nose.
  8. Teddy Bear Nose Replacement: step 8, image 1 of 1
    • Restuff the teddy bear’s nose with the stuffing you took out.
    • You may need to add more stuffing if the bear’s nose looks flat or deflated.
  9. Teddy Bear Nose Replacement: step 9, image 1 of 1
    • Thread the needle with about 18 inches of thread the same color as the bear's fur or stitches.
  10. Teddy Bear Nose Replacement: step 10, image 1 of 3 Teddy Bear Nose Replacement: step 10, image 2 of 3 Teddy Bear Nose Replacement: step 10, image 3 of 3
    • Sew the teddy bear’s face using a whip stitch until the opening is completely closed.
    • For help with sewing a whip stitch, follow this guide: How to Sew a Whip Stitch.
  11. Teddy Bear Nose Replacement: step 11, image 1 of 2 Teddy Bear Nose Replacement: step 11, image 2 of 2
    • Once the face is completely sewn shut, knot the end of the thread, and cut off the excess.
Finish Line
Nazib Khan
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 85
All Time: 5,670
