Teenage Engineering OP-Z Back Cover Replacement
  1. Teenage Engineering OP-Z Back Cover Replacement, Back Cover: step 1, image 1 of 3 Teenage Engineering OP-Z Back Cover Replacement, Back Cover: step 1, image 2 of 3 Teenage Engineering OP-Z Back Cover Replacement, Back Cover: step 1, image 3 of 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Back Cover Replacement: step 2, image 1 of 2 Teenage Engineering OP-Z Back Cover Replacement: step 2, image 2 of 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Back Cover Replacement: step 3, image 1 of 1
    • Remove the bottom plate including the rubber feet.
Tobias Isakeit
129,825 Reputation
189 Guides authored
3 Guide Comments
and uhm where to order the backplate? :/
boombipbass - Reply
Same question
Grant Dacklin -
Do you not sell the plate anymore?
Jason - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 33
All Time: 2,019
