Teenage Engineering OP-Z Battery Replacement
Tobias Isakeit
Tobias Isakeit and one other contributor
Last updated on August 11, 2023
50 seconds
Very easy
Featured Guide
Introduction
Go to step 1
Use this guide to replace a worn-out or dead battery in your OP-Z.
Parts
Tools
  • Spudger
    Spudger
Show more…
  1. Teenage Engineering OP-Z Battery Replacement, Back Cover: step 1, image 1 of 3 Teenage Engineering OP-Z Battery Replacement, Back Cover: step 1, image 2 of 3 Teenage Engineering OP-Z Battery Replacement, Back Cover: step 1, image 3 of 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Battery Replacement: step 2, image 1 of 2 Teenage Engineering OP-Z Battery Replacement: step 2, image 2 of 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Battery Replacement: step 3, image 1 of 1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Battery Replacement, Battery: step 4, image 1 of 2 Teenage Engineering OP-Z Battery Replacement, Battery: step 4, image 2 of 2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Battery Replacement: step 5, image 1 of 2 Teenage Engineering OP-Z Battery Replacement: step 5, image 2 of 2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Ask our Answers community for help.
4 other people completed this guide.
Tobias Isakeit
123,935 Reputation
189 Guides authored
One Comment
Does anyone know if there a way to purchase this battery in Australia? the link for the battery above says not available in Australia.. Does anyone know of another source? thanks
richard - Reply
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 162
All Time: 8,517
