Teenage Engineering OP-Z Expansion Module Replacement
  1. Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: step 1, image 1 of 3 Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: step 1, image 2 of 3 Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: step 1, image 3 of 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Expansion Module Replacement: step 2, image 1 of 2 Teenage Engineering OP-Z Expansion Module Replacement: step 2, image 2 of 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Expansion Module Replacement: step 3, image 1 of 1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Expansion Module Replacement, Expansion Module: step 4, image 1 of 2 Teenage Engineering OP-Z Expansion Module Replacement, Expansion Module: step 4, image 2 of 2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  5. Teenage Engineering OP-Z Expansion Module Replacement: step 5, image 1 of 1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
Tobias Isakeit
129,781 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 19
All Time: 1,276
