Tefal BI 5625 Water Kettle Lid Opening Spring Trigger Replacement
  1. Tefal BI 5625 Water Kettle Lid Opening Spring Trigger Replacement, Spring Trigger: step 1, image 1 of 2 Tefal BI 5625 Water Kettle Lid Opening Spring Trigger Replacement, Spring Trigger: step 1, image 2 of 2
    • Firstly open the lid of the kettle by pressing the button and manually pulling up the lid.
  2. Tefal BI 5625 Water Kettle Lid Opening Spring Trigger Replacement: step 2, image 1 of 2 Tefal BI 5625 Water Kettle Lid Opening Spring Trigger Replacement: step 2, image 2 of 2
    • Secondly detach the lid . To do so pull back the lid to access the two screws visible in the image. Using a screwdriver unscrew the screws.
    • Using force unlock the snap fit to remove this component. A screwdriver may be needed to complete this.
  3. Tefal BI 5625 Water Kettle Lid Opening Spring Trigger Replacement: step 3, image 1 of 3 Tefal BI 5625 Water Kettle Lid Opening Spring Trigger Replacement: step 3, image 2 of 3 Tefal BI 5625 Water Kettle Lid Opening Spring Trigger Replacement: step 3, image 3 of 3
    • To access the springs unscrew the 2 screws.
    • Using a flat head screwdriver lift up the component and remove it from assembly.
  4. Tefal BI 5625 Water Kettle Lid Opening Spring Trigger Replacement: step 4, image 1 of 1
    • Remove the springs, a scribe may be needed to assist in this.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 56
All Time: 14,625
