Tefal Thick N Thin Toaster 815032 Side Panels Replacement
  1. Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: step 1, image 1 of 3 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: step 1, image 2 of 3 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: step 1, image 3 of 3
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: step 2, image 1 of 1
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: step 3, image 1 of 2 Tefal Thick N Thin Toaster 815032 Side Panels Replacement: step 3, image 2 of 2
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
Kristen Gismondi
85,242 Reputation
215 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,067 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 5
All Time: 199
