Tello Quadcopter Propeller Replacement
  1. Tello Quadcopter Propeller Replacement, Propeller: step 1, image 1 of 1
    • Identify the propeller being replaced.
    • Gather the required materials.
  2. Tello Quadcopter Propeller Replacement: step 2, image 1 of 2 Tello Quadcopter Propeller Replacement: step 2, image 2 of 2
    • Next, remove the battery by grasping each side and pulling it out.
  3. Tello Quadcopter Propeller Replacement: step 3, image 1 of 3 Tello Quadcopter Propeller Replacement: step 3, image 2 of 3 Tello Quadcopter Propeller Replacement: step 3, image 3 of 3
    • Remove the propeller by inserting the provided tool between the propeller and drone.
    • Needle nose pliers can be used instead. Use the pliers to grasp directly below the propeller.
    • Gently lift the propeller from the socket using your choice of tool.
  4. Tello Quadcopter Propeller Replacement: step 4, image 1 of 3 Tello Quadcopter Propeller Replacement: step 4, image 2 of 3 Tello Quadcopter Propeller Replacement: step 4, image 3 of 3
    • After removing the old propeller, orient the new propeller over the empty socket.
    • Insert a new propeller by applying force. The propeller should snap into place.
You have successfully completed replacing the damaged propellor.
Cody White
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 15
All Time: 2,171
