Testing the Starbucks Barista Heating Element
  1. Testing the Starbucks Barista Heating Element, Testing the Starbucks Barista Heating Element: step 1, image 1 of 2 Testing the Starbucks Barista Heating Element, Testing the Starbucks Barista Heating Element: step 1, image 2 of 2
    • Remove the 6 Phillips #1 screws from the back panel.
    • Remove the back panel.
  2. Testing the Starbucks Barista Heating Element: step 2, image 1 of 1
    • Make sure the machine is turned off and unplugged.
    • Set your voltmeter in continuity mode and place the leads on the two 90 degree prongs on the boiler's heating element.
    • It does not matter which lead touches which prong as you're just testing for a break, or "open" in the heating element circuit.'''
    • If the voltmeter shows 0, or "open", then there is an issue with the heating element's continuity and it needs to be replaced.
    • If given a reading, then your heating element is fine.
  3. Testing the Starbucks Barista Heating Element: step 3, image 1 of 1
    • In the water reservoir, place mixture of de-calcifying agent and water as directed on the product label.
    • Place a cup, to catch fluid, underneath the portafilter.
    • Run Barista, as if making coffee, for the amount of time directed by the de-calcifying product.
    • See the links section of the device page for further directions.
11 other people completed this guide.
Brian McMurray
219 Reputation
1 Guide authored
Cal Poly, Team 4-42, Regan Winter 2011 Member of Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Members
11 Guides authored
6 Guide Comments
I did this a few months ago and the boiler was full of rusty gunk. This guide sure did help me out.
oguitar200 - Reply
the same here - it was disgusting... was afraid to have damaged it while cleaning it. tested it yesterday already... just going through all the steps to validate function of the units.
Martin Zeitler -
hi ! we have Starbucks Barisa Milano. some how it didnt want switch on! my husband wanted to have a look but we cant open. do you gave any guidence?
Zorigoo Purev - Reply
I have a Barista and want to change the pressure washer of the coffee maker arm.
can any one help me?
sonnynima - Reply
I feel the temperature of the espressos i’m making is not hot enough. How do i raise the thermostat to activate the Ready light at a higher temp?
Tim Furnish - Reply
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 61
All Time: 21,332
