Texas Instruments TI BA II PLUS Battery Replacement
  1. Texas Instruments TI BA II PLUS  Battery Replacement, Battery: step 1, image 1 of 2 Texas Instruments TI BA II PLUS  Battery Replacement, Battery: step 1, image 2 of 2
    • Switch off the calculator by pressing the button at the top right corner.
  2. Texas Instruments TI BA II PLUS  Battery Replacement: step 2, image 1 of 1
    • Turn over the calculator so the backside of the calculator is facing upwards.
    • Remove the four 2mm Phillips #00 screws from the bottom cover.
  3. Texas Instruments TI BA II PLUS  Battery Replacement: step 3, image 1 of 1
    • Open a small gap at the bottom of the calculator, using a spudger or your fingers.
    • Move your thumb from the bottom edge to the top.
    • Be gentle when separating the cases to avoid breaking the clips.
  4. Texas Instruments TI BA II PLUS  Battery Replacement: step 4, image 1 of 3 Texas Instruments TI BA II PLUS  Battery Replacement: step 4, image 2 of 3 Texas Instruments TI BA II PLUS  Battery Replacement: step 4, image 3 of 3
    • Use a spudger to remove the battery from the cage at the bottom of the motherboard.
  5. Texas Instruments TI BA II PLUS  Battery Replacement: step 5, image 1 of 1
    • Replace the battery with the new CR2032 Lithium Battery in the battery cage.
  6. Texas Instruments TI BA II PLUS  Battery Replacement: step 6, image 1 of 2 Texas Instruments TI BA II PLUS  Battery Replacement: step 6, image 2 of 2
    • Reattach the calculator cases, beginning from the top edge.
    • Use the Phillips #00 screwdriver to replace the 2.00 mm screws.
Finish Line
5 other people completed this guide.
Peipei Yu
268 Reputation
1 Guide authored
3 Guide Comments
It's amazing that this calculator can break. I am an accountant student in college and despite modern technologies and the rather powerful functionality of modern smartphones, I like to use just such a calculator for financial calculations.
AlGorFun - Reply
Great guide, thanks! The spudger was necessary for me to separate the case, as I couldn’t separate it with my fingers alone.
Jonathan - Reply
使用2.5mm的螺丝刀更好,2mm可能会打滑
C Max - Reply
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 163
All Time: 30,562
