Texas Instruments TI-30X IIS Battery Replacement
  1. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: step 1, image 1 of 3 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: step 1, image 2 of 3 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: step 1, image 3 of 3
    • Ensure that your calculator is a TI-30X IIS by looking in the top right corner of the front face.
    • Look at the rear face of the calculator and locate the four case screws. There are two at the top and two at the bottom.
  2. Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: step 2, image 1 of 2 Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: step 2, image 2 of 2
    • Use a Philips 00 screwdriver to remove the four case screws on the rear face of the calculator.
    • Be sure to save the screws in a secure place as they are small and easy to lose. They will be needed later for reassembly.
  3. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: step 3, image 1 of 3 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: step 3, image 2 of 3 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: step 3, image 3 of 3
    • With all four screws removed, use a flathead screwdriver or similar flat object to separate the front and rear casings.
    • There are six clips that keep the cases together. These areas will require extra force to separate, but use caution to not fracture the plastic pieces.
  4. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: step 4, image 1 of 3 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: step 4, image 2 of 3 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: step 4, image 3 of 3
    • With the rear case off, the battery is exposed and accessible.
    • Using a pointed tool, slide the battery out of its terminal towards the near edge.
    • Once the battery is protruding from the contacts, remove it with your fingers.
  5. Texas Instruments TI-30X IIS Battery Replacement, Replacing Battery: step 5, image 1 of 1
    • Properly dispose of the old battery.
    • Replace the battery with an identical one, positive terminal up and negative terminal facing down towards the circuit board.
    • Following the previous steps in the reverse order to reassemble the calculator.
20 other people completed this guide.
Ryan
515 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 113
All Time: 33,304
