Texas Instruments TI-80 Keyboard Mat Replacement
  1. Texas Instruments TI-80 Keyboard Mat Replacement, Batteries: step 1, image 1 of 1
    • Locate battery cover on the back of the case.
    • Slide battery cover to the right reveal the batteries.
  2. Texas Instruments TI-80 Keyboard Mat Replacement: step 2, image 1 of 1
    • Remove battery cover.
    • Slide the red lock down.
    • Slide the metal tab to the right of the top battery.
    • Remove the 3-Volt Lithium Coin Cell Battery.
    • Slide the red lock up.
    • Slide the metal tab to the right of the bottom battery.
  3. Texas Instruments TI-80 Keyboard Mat Replacement, Back Case: step 3, image 1 of 3 Texas Instruments TI-80 Keyboard Mat Replacement, Back Case: step 3, image 2 of 3 Texas Instruments TI-80 Keyboard Mat Replacement, Back Case: step 3, image 3 of 3
    • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
    • Unscrew four 7.15 mm screws from back casing.
    • Using the blue plastic opener tool along the seam of the case, pry off front casing.
    • Start prying from the bottom of the calculator as the casing hooks into the top.
  4. Texas Instruments TI-80 Keyboard Mat Replacement, Motherboard and Screen: step 4, image 1 of 2 Texas Instruments TI-80 Keyboard Mat Replacement, Motherboard and Screen: step 4, image 2 of 2
    • Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
    • Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
    • Using the blue plastic opening tool, pry the Motherboard up.
    • Using the blue plastic opening tool, pry up the screen from the screen mount.
  5. Texas Instruments TI-80 Keyboard Mat Replacement, Check keyboard mat: step 5, image 1 of 2 Texas Instruments TI-80 Keyboard Mat Replacement, Check keyboard mat: step 5, image 2 of 2
    • Check the rubber mat for damage or obstruction at the location of non-functioning buttons.
    • Flip the mat over to assess dirt and damage.
    • Replace the mat if it is damaged.
    • Clean off the back of the Motherboard as necessary. The mat lies on top, so dirt and debris may build up. Repeat cleaning as needed.
brian decater
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 384
