Texas Instruments TI-83 Plus Backup Battery Replacement
  1. Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: step 1, image 1 of 2 Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: step 1, image 2 of 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Backup Battery Replacement: step 2, image 1 of 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Backup Battery Replacement: step 3, image 1 of 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
Clay
38 Reputation
1 Guide authored
Cal Poly, Team 18-37, Regan Fall 2012 Member of Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Members
5 Guides authored
2 Guide Comments
Will this wipe the memory?
John Osborne - Reply
Yes I found one and have been trying to get it together for a high schooler I had one when I took trig in college and it was very helpful
Jack Irvin - Reply
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 79
All Time: 23,435
