The Beatles Rock Band Drum Set Battery Replacement
Zach Richter
Zach Richter and 2 other contributors
Last updated on April 13, 2017
2 minutes
Very easy
Introduction
Go to step 1
We are going to be explaining the step-by-step procedure to replace batteries in your Rock Band drum set. Before you begin the battery replacement, make sure you have 3 AA batteries. Make sure not to mix the old batteries with the new ones to ensure that you put in completely new batteries.
  1. The Beatles Rock Band Drum Set Battery Replacement, Batteries: step 1, image 1 of 2 The Beatles Rock Band Drum Set Battery Replacement, Batteries: step 1, image 2 of 2
    • Remove battery door from the bottom of the drum set
  2. The Beatles Rock Band Drum Set Battery Replacement: step 2, image 1 of 1
    • Remove batteries from battery compartment
    • This device requires 3 AA batteries
Zach Richter
549 Reputation
5 Guides authored
Cal Poly, Team 13-3, Banghart Winter 2017 Member of Cal Poly, Team 13-3, Banghart Winter 2017
CPSU-BANGHART-W17S13G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 37
All Time: 2,523
