The Beatles Rock Band Drum Set Foot Pedal Replacement
  1. The Beatles Rock Band Drum Set Foot Pedal Replacement, Foot Pedal: step 1, image 1 of 1
    • Unplug the coiled wire from back of upper assembly.
  2. The Beatles Rock Band Drum Set Foot Pedal Replacement: step 2, image 1 of 1
    • Remove foot pedal from base assembly.
  3. The Beatles Rock Band Drum Set Foot Pedal Replacement: step 3, image 1 of 1
    • Remove the two Phillips size J0 screws holding the cover plate on the top of the foot pedal.
  4. The Beatles Rock Band Drum Set Foot Pedal Replacement: step 4, image 1 of 1
    • The small sensor is a Magnetic Glass Reed Switch. You will need to unsolder it from the pcb and replace it with a new one.
Zach Richter
549 Reputation
5 Guides authored
Cal Poly, Team 13-3, Banghart Winter 2017 Member of Cal Poly, Team 13-3, Banghart Winter 2017
CPSU-BANGHART-W17S13G3
4 Members
6 Guides authored
3 Comments
How can I connect my rockband drums to my laptop to make it a personal drum pad?
clem4uandme - Reply
Email me
Abrajoe11@yahoo.com
Thanks
clem4uandme - Reply
Can't you just replace the magnetic sensor??
Lena - Reply
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 79
All Time: 4,792
