The Beatles Rock Band Drum Set Front Button Replacement
  1. The Beatles Rock Band Drum Set Front Button Replacement, Front Buttons: step 1, image 1 of 1
    • Remove the four Phillips size J1 screws from the corners of the bottom module.
    • Removing the screws requires a thin screwdriver.
  2. The Beatles Rock Band Drum Set Front Button Replacement: step 2, image 1 of 3 The Beatles Rock Band Drum Set Front Button Replacement: step 2, image 2 of 3 The Beatles Rock Band Drum Set Front Button Replacement: step 2, image 3 of 3
    • Open the bottom module. Disconnect the five wire clips as shown in the pictures.
  3. The Beatles Rock Band Drum Set Front Button Replacement: step 3, image 1 of 2 The Beatles Rock Band Drum Set Front Button Replacement: step 3, image 2 of 2
    • Remove the four Phillips #1 sized screws holding the main circuit board. Rotate the board up and out, exposing the buttons.
  4. The Beatles Rock Band Drum Set Front Button Replacement: step 4, image 1 of 1
    • The buttons can be pushed up from the bottom to be removed.
Zach Richter
549 Reputation
5 Guides authored
Cal Poly, Team 13-3, Banghart Winter 2017 Member of Cal Poly, Team 13-3, Banghart Winter 2017
CPSU-BANGHART-W17S13G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 1,205
