The Beatles Rock Band Drum Set Leg Replacement
Zach Richter
Zach Richter and 2 other contributors
Last updated on April 13, 2017
1 minute
Very easy
Introduction
Go to step 1
For this repair guide, you will need enough space around you so that you can place certain parts of the drum set on the side as you work on removing the legs of the drum set.
  1. The Beatles Rock Band Drum Set Leg Replacement, Legs: step 1, image 1 of 1
    • Flip the leg retention clips on the back of the upper assembly down.
  2. The Beatles Rock Band Drum Set Leg Replacement: step 2, image 1 of 1
    • Remove upper assembly from legs.
  3. The Beatles Rock Band Drum Set Leg Replacement: step 3, image 1 of 1
    • Remove legs from bottom support structure.
Zach Richter
549 Reputation
5 Guides authored
Cal Poly, Team 13-3, Banghart Winter 2017 Member of Cal Poly, Team 13-3, Banghart Winter 2017
CPSU-BANGHART-W17S13G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 36
All Time: 869
