The Beatles Rock Band Hofner Bass Directional Pad Replacement
  1. The Beatles Rock Band Hofner Bass Directional Pad Replacement, Back Plate: step 1, image 1 of 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Directional Pad Replacement: step 2, image 1 of 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Directional Pad Replacement: step 3, image 1 of 2 The Beatles Rock Band Hofner Bass Directional Pad Replacement: step 3, image 2 of 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Directional Pad Replacement, Directional Pad: step 4, image 1 of 2 The Beatles Rock Band Hofner Bass Directional Pad Replacement, Directional Pad: step 4, image 2 of 2
    • Use a J1 Phillips screwdriver to remove the six screws 10mm around the brown button cover.
  5. The Beatles Rock Band Hofner Bass Directional Pad Replacement: step 5, image 1 of 1
    • Remove the directional pad button,
Jacob
601 Reputation
6 Guides authored
Cal Poly, Team 8-4, Banghart Winter 2017 Member of Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
3 Members
6 Guides authored
One Comment
I need help re-assembling the Effect Switch. I have a tiny spring and steel ball that I don't know how to put back together.
Jay Kap - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 375
