The Beatles Rock Band Hofner Bass Strummer Bar Replacement
  1. The Beatles Rock Band Hofner Bass Strummer Bar Replacement, Back Plate: step 1, image 1 of 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Strummer Bar Replacement: step 2, image 1 of 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Strummer Bar Replacement: step 3, image 1 of 2 The Beatles Rock Band Hofner Bass Strummer Bar Replacement: step 3, image 2 of 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Strummer Bar Replacement, Strummer Bar: step 4, image 1 of 1
    • Use a J1 Phillips head screwdriver to remove the four 10mm screws at the corners of the black casing.
  5. The Beatles Rock Band Hofner Bass Strummer Bar Replacement: step 5, image 1 of 1
    • Remove the connection from the board, so that the strummer is no longer connected.
    • Carefully take the strummer out of the guitar, now that it is no longer connected.
    • Now the strummer is completely removed.
Jacob
601 Reputation
6 Guides authored
Cal Poly, Team 8-4, Banghart Winter 2017 Member of Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
3 Members
6 Guides authored
One Comment
How/where do I purshase a new strummer bar?
Peter Grav - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 26
All Time: 1,067
