The Claw Battery Replacement
  1. The Claw Battery Replacement, Batteries: step 1, image 1 of 1
    • Hold The Claw machine upright so that the controls are facing you.
  2. The Claw Battery Replacement: step 2, image 1 of 1
    • Turn the device upside down keeping the controls facing in your direction.
  3. The Claw Battery Replacement: step 3, image 1 of 1
    • Locate the battery compartment door on the bottom cover of The Claw.
    • Loosen the screw from the battery compartment door with your phillips head screwdriver.
  4. The Claw Battery Replacement: step 4, image 1 of 1
    • Open the door and insert the 3 D-cell batteries using the correct configuration that is labeled on the inside of the compartment.
    • If the batteries are not placed in the right configuration the device will not operate. make sure to identify positive and negative sides of the battery and follow the configuration on the device.
Alain Pierre
1,188 Reputation
9 Guides authored
One Comment
daiobn ht45o9iyjugggjvj nvj vnv jnkrfdoelcbigvfcofrbbvfgb4vg3rcf2edebb
Jennifer Mateo - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 33
All Time: 3,022
