Introduction
Use this guide to replace an old or faulty battery and revitalize your ThinkPad. If your battery is swollen, take appropriate precautions.
Use a Size 0 Philips screwdriver to loosen the nine screws on the bottom of the case. They will not come out entirely, but you will feel when they are loose enough.
You will need to remove the rubber pads from the bottom three screws using a pair of tweezers.
Use a spudger or other plastic tool to push the battery connector in the direction of the arrow, removing it from its socket.
