ThinkPad T420 Memory Replacement
  1. Tool used on this step:
    Essential Electronics Toolkit
    $29.95
    Buy
  2. ThinkPad T420 Memory Replacement, Unlock the battery: step 2, image 1 of 3 ThinkPad T420 Memory Replacement, Unlock the battery: step 2, image 2 of 3 ThinkPad T420 Memory Replacement, Unlock the battery: step 2, image 3 of 3
    • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
    • Unlock the latch locking the battery in the laptop.
    • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
  3. ThinkPad T420 Memory Replacement, Release the battery: step 3, image 1 of 3 ThinkPad T420 Memory Replacement, Release the battery: step 3, image 2 of 3 ThinkPad T420 Memory Replacement, Release the battery: step 3, image 3 of 3
    • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
  4. ThinkPad T420 Memory Replacement, Remove the RAM door: step 4, image 1 of 3 ThinkPad T420 Memory Replacement, Remove the RAM door: step 4, image 2 of 3 ThinkPad T420 Memory Replacement, Remove the RAM door: step 4, image 3 of 3
    • EET owners: Your kit has this bit. No purchase needed.
    • If you are removing this cover to upgrade/replace your lower RAM module, the keyboard screw DOES NOT need to be removed.
    • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
    • Loosen the screw in red (Phillips #2). This screw stays captive in the bottom RAM door cover, and does not need to be removed.
    • Pull the cover up with a fingernail or a nonmarring pry tool.
    • Remove the screw retaining the keyboard.
  5. ThinkPad T420 Memory Replacement, Remove the keyboard: step 5, image 1 of 3 ThinkPad T420 Memory Replacement, Remove the keyboard: step 5, image 2 of 3 ThinkPad T420 Memory Replacement, Remove the keyboard: step 5, image 3 of 3
    • Open the laptop.
    • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
    • Once the keyboard is loose, remove it from the chassis.
  6. ThinkPad T420 Memory Replacement, Disconnect the keyboard: step 6, image 1 of 3 ThinkPad T420 Memory Replacement, Disconnect the keyboard: step 6, image 2 of 3 ThinkPad T420 Memory Replacement, Disconnect the keyboard: step 6, image 3 of 3
    • To reinstall the keyboard, refer to the steps in this guide.
    • This step can be skipped if you remove the keyboard to upgrade/replace the RAM. However, disconnecting it may allow for better access to the upper (Keyboard) RAM module.
    • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
    • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
  7. ThinkPad T420 Memory Replacement, RAM module - Bottom: step 7, image 1 of 3 ThinkPad T420 Memory Replacement, RAM module - Bottom: step 7, image 2 of 3 ThinkPad T420 Memory Replacement, RAM module - Bottom: step 7, image 3 of 3
    • Unclip the RAM module by pulling the memory retention tabs back.
    • Remove the existing module by pulling the module from the side, at a 90 degree angle.
  8. ThinkPad T420 Memory Replacement, RAM module - keyboard: step 8, image 1 of 3 ThinkPad T420 Memory Replacement, RAM module - keyboard: step 8, image 2 of 3 ThinkPad T420 Memory Replacement, RAM module - keyboard: step 8, image 3 of 3
    • Lift the plastic cover hiding the RAM module.
    • Unlatch the tabs retaining the memory module.
    • Pull the module out from a 90 degree angle.
15 other people completed this guide.
Nick
98,758 Reputation
63 Guides authored
Master Techs Member of Master Techs
Community
329 Members
1,452 Guides authored
2 Guide Comments
What tool might one use as a pry?
commander - Reply
The plastic pry tool will also work for the bottom RAM/mSATA part. I can usually get it open without the assistance of pry tools.
Nick -
Past 24 Hours: 6
Past 7 Days: 32
Past 30 Days: 151
All Time: 20,864
