ThinkPad X1 Carbon Wireless Card Replacement
  1. ThinkPad X1 Carbon Wireless Card Replacement, Loosen Cover Screws: step 1, image 1 of 1
    • Using the #0 Phillips screwdriver, loosen the seven cover screws. they will not come all of the way out.
  2. ThinkPad X1 Carbon Wireless Card Replacement: step 2, image 1 of 1
    • Using the spudger pop the cover loose and remove.
  3. ThinkPad X1 Carbon Wireless Card Replacement, Disconnect Battery: step 3, image 1 of 1
    • Use only plastic tools to disconnect battery cable
    • Slide battery connector in the direction if the arrow to disconnect.
    • You can leave the battery or remove it using the red circles for the screw locations.
  4. ThinkPad X1 Carbon Wireless Card Replacement: step 4, image 1 of 1
    • Remove screw holding the wireless card in place.
  5. ThinkPad X1 Carbon Wireless Card Replacement, Remove Antenna Cables: step 5, image 1 of 1
    • Carefully remove the antenna cables and slide out the card in the direction of the arrow.
    • The gray connector is on the top. The black connector is closer to the battery.
3 other people completed this guide.
Mike
1,834 Reputation
5 Guides authored
iReconstruction Member of iReconstruction
Business
1 Member
11 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 55
All Time: 5,504
