Thinkpad L13 Cleaning Fan & Replacing Thermal Paste
  1. Thinkpad L13 Cleaning Fan & Replacing Thermal Paste, Remove Case: step 1, image 1 of 1
    • Screws are attached to the panel
    • After loosening the screws you can start to separate the lower panel from the upper. I found it easiest to start at the back in between the two hinges, and moving to the sides.
  2. Thinkpad L13 Cleaning Fan & Replacing Thermal Paste, Disconnect Battery: step 2, image 1 of 1
    • Disconnect the plug from the socket (rectangle)
    • If you wist to remove the battery completely you can unscrew and lift it out from the case.
  3. Thinkpad L13 Cleaning Fan & Replacing Thermal Paste, Inspect & Clean Fan: step 3, image 1 of 1
    • Use alcohol spray, with swabs or lint-free coffee filters, in order to clean out dust in the air vents.
    • If you're just cleaning the fan you can attempt to clean that while it's fixed to the board, I didn't do this myself though.
    • You can see the fan connection with the motherboard highlighted in the rectangle.
  4. Thinkpad L13 Cleaning Fan & Replacing Thermal Paste, Remove Fan & Heatsink: step 4, image 1 of 3 Thinkpad L13 Cleaning Fan & Replacing Thermal Paste, Remove Fan & Heatsink: step 4, image 2 of 3 Thinkpad L13 Cleaning Fan & Replacing Thermal Paste, Remove Fan & Heatsink: step 4, image 3 of 3
    • To remove the fan and heat sink/pipe, remove the screws, & disconnect fan connection from board, then lift out from case.
  5. Thinkpad L13 Cleaning Fan & Replacing Thermal Paste, Clean Old & Reapply New Thermal Paste: step 5, image 1 of 2 Thinkpad L13 Cleaning Fan & Replacing Thermal Paste, Clean Old & Reapply New Thermal Paste: step 5, image 2 of 2
    • Clean the old paste away from the chips and the heatsink using the alcohol and cotton swabs and then apply your new thermal paste so it will cover the metal surface of the chips.
    • Place the Heatsink and Fan back into the case carefully, ensuring the paste will get distributed evenly underneath as you tighten the screws again.
  6. Thinkpad L13 Cleaning Fan & Replacing Thermal Paste, Enjoy The Low CPU Temps 👍: step 6, image 1 of 1
    • Hopefully this helps, I'm averaging between 30 & 40 degrees C now.
    • I recommend making sure you've washed your hands of any potential old thermal paste that might've been picked up while cleaning.
3 other people completed this guide.
Innes Ford
273 Reputation
1 Guide authored
OPEN Member of OPEN
Community
84 Members
25 Guides authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 38
Past 30 Days: 151
All Time: 2,092
