Thrustmaster T Flight Hotas 4 Bottom Panel Replacement
  1. Thrustmaster T Flight Hotas 4 Bottom Panel Replacement, J1 Screws on Bottom Panel: step 1, image 1 of 1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Turn the controller upside down.
    • Remove the 20 mm J1 JIS head screw.
    • Remove the six 12 mm J1 JIS head screws.
    • Remove the two 6 mm J1 JIS head screws.
  2. Thrustmaster T Flight Hotas 4 Bottom Panel Replacement: step 2, image 1 of 1
    • Insert opening tool or finger into the divet located beneath the USB port.
  3. Thrustmaster T Flight Hotas 4 Bottom Panel Replacement, Bottom Panel: step 3, image 1 of 2 Thrustmaster T Flight Hotas 4 Bottom Panel Replacement, Bottom Panel: step 3, image 2 of 2
    • Gently pull the panel away from the controller.
2 other people completed this guide.
Aaron Banaga
556 Reputation
4 Guides authored
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Members
23 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 79
All Time: 6,818
