Thrustmaster T3PA Cable Replacement
  1. Thrustmaster T3PA Cable Replacement, Cable: step 1, image 1 of 3 Thrustmaster T3PA Cable Replacement, Cable: step 1, image 2 of 3 Thrustmaster T3PA Cable Replacement, Cable: step 1, image 3 of 3
    • Start by flipping it over, rest it on the pedals. make sure the wire is pointing towards the bottom. remove the 14 Screws on the back with a PH2 Phillips head screwdriver and carefully pop it off.
    • (DO NOT COMPLETELY PULL IT OFF BECAUSE OF WIRES.)
  2. Thrustmaster T3PA Cable Replacement: step 2, image 1 of 2 Thrustmaster T3PA Cable Replacement: step 2, image 2 of 2
    • Unplug the wire connected to the bottom (the one circled in the image).
  3. Thrustmaster T3PA Cable Replacement: step 3, image 1 of 2 Thrustmaster T3PA Cable Replacement: step 3, image 2 of 2
    • Once the bottom is separated, remove the glue holding the wire and pull it out.
For reassembly, simply follow the steps in reverse.
3 other people completed this guide.
John.gmot
384 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 77
All Time: 1,369
