Thrustmaster T3PA Pedal Spring Replacement
  1. Thrustmaster T3PA Pedal Spring Replacement, Pedal Spring: step 1, image 1 of 2 Thrustmaster T3PA Pedal Spring Replacement, Pedal Spring: step 1, image 2 of 2
    • Start by removing the screws in the pedal that you are changing with a Torx t10H screwdriver.
  2. Thrustmaster T3PA Pedal Spring Replacement: step 2, image 1 of 2 Thrustmaster T3PA Pedal Spring Replacement: step 2, image 2 of 2
    • Remove the 14 Screws on the back with a PH2 Phillips head screwdriver and carefully pop it off.
    • (DO NOT COMPLETELY PULL IT OFF BECAUSE OF WIRES, INSTEAD UNPLUG IT)
  3. Thrustmaster T3PA Pedal Spring Replacement: step 3, image 1 of 1
    • Once open, remove the 6 screws holding the pedal in place with the same PH2 screwdriver. Then pull out the pedal.
    • NOTE: DO NOT UNSCREW THE MIDDLE SCREW, IT KEEPS THE SPRING IN PLACE.
  4. Thrustmaster T3PA Pedal Spring Replacement: step 4, image 1 of 3 Thrustmaster T3PA Pedal Spring Replacement: step 4, image 2 of 3 Thrustmaster T3PA Pedal Spring Replacement: step 4, image 3 of 3
    • Once it has been removed, pull the pedal forward and simply remove the spring.
    • NOTE: BE CAREFUL WITH THE GREASE, WASH YOUR HANDS ONCE YOU HAVE TOUCHED IT, DO NOT TOUCH YOUR EYES OR FACE WITH IT ON YOUR HANDS.
For reassembly, simply follow the steps in reverse.
3 other people completed this guide.
John.gmot
384 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 62
All Time: 1,165
