Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement
  1. Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement: step 2, image 1 of 2 Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement: step 2, image 2 of 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
2 other people completed this guide.
Mohammed Alsogair
339 Reputation
2 Guides authored
USF Tampa, Team S1-G33, Cagle Fall 2017 Member of USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 32
All Time: 5,563
