Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement
  1. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement, Gas/Break Pedal: step 1, image 1 of 3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement, Gas/Break Pedal: step 1, image 2 of 3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement, Gas/Break Pedal: step 1, image 3 of 3
    • Start by removing both pedals. Remove the two black 20mm screws on each pedal using a PH2 Phillips head screw driver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: step 2, image 1 of 3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: step 2, image 2 of 3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: step 2, image 3 of 3
    • Remove the 10mm long black screws on the back of the base using a PH2 Phillips head screw driver. There are 13 screws total.
    • Gently lift cover out to access inside.
    • There is a screw behind the cable.
    • In the picture you see a plastic opining tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  3. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: step 3, image 1 of 2 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: step 3, image 2 of 2
    • Push the pin that holds the pedal out from middle outward.
    • There are two springs that hold the pedal upward. Make sure the pin goes through the springs and the pedal when installing new pedal.
  4. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: step 4, image 1 of 1
    • Install the new pedal with springs and pin and make sure that the pin holds them together.
    • Add a little grease on pin when installing the new pedal.
    • Repeat steps in reverse to reassemble device.
    • Wash your hands after you finish dealing with grease. it is a dangerous material will cause problems if it gets in your eyes or get swallowed.
2 other people completed this guide.
Mario Nunez
421 Reputation
3 Guides authored
USF Tampa, Team S1-G33, Cagle Fall 2017 Member of USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 Members
5 Guides authored
6 Comments
Hi, where can you get replacement springs? Cannot find anything online that sells this specific diameter and angle at both ends? Can I contact Thrustmaster to get more springs or a replacement pedal set?
Alex Ruiz - Reply
I am also looking for this spring. Any help would be appreciated.
thanks
Maxime Viens -
Me too. Are these springs available?
Jay Nicholson - Reply
I only need 1 spring, not 10....
Anyone selling 1 spring?
fnaf master101 - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 82
All Time: 11,803
