Timex W-10 Children's Watch Battery Replacement
  1. Timex W-10 Children's Watch Battery Replacement, Battery: step 1, image 1 of 3 Timex W-10 Children's Watch Battery Replacement, Battery: step 1, image 2 of 3 Timex W-10 Children's Watch Battery Replacement, Battery: step 1, image 3 of 3
    • Pull on the watch strap through the top of the strap buckle to unlock the strap.
  2. Timex W-10 Children's Watch Battery Replacement: step 2, image 1 of 2 Timex W-10 Children's Watch Battery Replacement: step 2, image 2 of 2
    • Once the strap has been unlocked, hold onto the strap buckle and pull away from the watch to completely remove the band.
  3. Timex W-10 Children's Watch Battery Replacement: step 3, image 1 of 2 Timex W-10 Children's Watch Battery Replacement: step 3, image 2 of 2
    • Use the PH00 screwdriver to remove the four screws from each corner of the rear metal cover.
  4. Timex W-10 Children's Watch Battery Replacement: step 4, image 1 of 2 Timex W-10 Children's Watch Battery Replacement: step 4, image 2 of 2
    • Gently remove the back plate to expose the battery.
  5. Timex W-10 Children's Watch Battery Replacement: step 5, image 1 of 2 Timex W-10 Children's Watch Battery Replacement: step 5, image 2 of 2
    • The battery spring will propel the battery upward as soon as the base cover is removed. Be sure to place the battery in a safe spot.
2 other people completed this guide.
2 Comments
I'm looking for an adult Timex watch battery replacement that has a metal watch band.
Daniel Melendrez - Reply
Daniel Melendrez - June 12
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 45
All Time: 8,713
