Tivax MiTraveler 10Q-8 Speaker Replacement
  1. Tivax MiTraveler 10Q-8 Speaker Replacement, Rear Case: step 1, image 1 of 2 Tivax MiTraveler 10Q-8 Speaker Replacement, Rear Case: step 1, image 2 of 2
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Speaker Replacement: step 2, image 1 of 1
    • Locate a Phillips 2.88mm screw at the charging port.
  3. Tivax MiTraveler 10Q-8 Speaker Replacement: step 3, image 1 of 1
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 Speaker Replacement: step 4, image 1 of 1
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 Speaker Replacement: step 5, image 1 of 2 Tivax MiTraveler 10Q-8 Speaker Replacement: step 5, image 2 of 2
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 Speaker Replacement: step 6, image 1 of 2 Tivax MiTraveler 10Q-8 Speaker Replacement: step 6, image 2 of 2
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  7. Tivax MiTraveler 10Q-8 Speaker Replacement, Battery: step 7, image 1 of 1
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  8. Tivax MiTraveler 10Q-8 Speaker Replacement: step 8, image 1 of 1
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  9. Tivax MiTraveler 10Q-8 Speaker Replacement: step 9, image 1 of 2 Tivax MiTraveler 10Q-8 Speaker Replacement: step 9, image 2 of 2
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  10. Tivax MiTraveler 10Q-8 Speaker Replacement: step 10, image 1 of 3 Tivax MiTraveler 10Q-8 Speaker Replacement: step 10, image 2 of 3 Tivax MiTraveler 10Q-8 Speaker Replacement: step 10, image 3 of 3
    • Once both wires have been desoldered, remove the battery from the device.
  11. Tivax MiTraveler 10Q-8 Speaker Replacement, Speaker: step 11, image 1 of 1
    • With the face of the device down, locate the speaker in the upper right corner. The black oval shaped object.
    • Make sure Battery has been removed.
  12. Tivax MiTraveler 10Q-8 Speaker Replacement: step 12, image 1 of 2 Tivax MiTraveler 10Q-8 Speaker Replacement: step 12, image 2 of 2
    • A Phillips 3.88 mm screw holds the speaker in place.
    • Use a PH000 screwdriver to remove the screw.
  13. Tivax MiTraveler 10Q-8 Speaker Replacement: step 13, image 1 of 2 Tivax MiTraveler 10Q-8 Speaker Replacement: step 13, image 2 of 2
    • The speaker will be connected to two wires; one black and one red. Both run to the motherboard.
    • The wires will need to be soldered off the motherboard.
    • Locate where both wires are soldered to the motherboard.
    • Review How to Solder Here
  14. Tivax MiTraveler 10Q-8 Speaker Replacement: step 14, image 1 of 2 Tivax MiTraveler 10Q-8 Speaker Replacement: step 14, image 2 of 2
    • Work the iron where the red wire is soldered
    • The wire will release from the motherboard.
  15. Tivax MiTraveler 10Q-8 Speaker Replacement: step 15, image 1 of 3 Tivax MiTraveler 10Q-8 Speaker Replacement: step 15, image 2 of 3 Tivax MiTraveler 10Q-8 Speaker Replacement: step 15, image 3 of 3
    • Work the iron where the black wire is soldered.
    • The black wire will release from the motherboard.
    • After both wires have been soldered off, the speaker will release from the device.
Krista
131 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 112
