Toaster Oven Toasting Knob Replacement
  1. Toaster Oven Toasting Knob Replacement, Toasting knob: step 1, image 1 of 3 Toaster Oven Toasting Knob Replacement, Toasting knob: step 1, image 2 of 3 Toaster Oven Toasting Knob Replacement, Toasting knob: step 1, image 3 of 3
    • Remove the two 4mm by 8mm screws from the back of the toaster oven.
  2. Toaster Oven Toasting Knob Replacement: step 2, image 1 of 3 Toaster Oven Toasting Knob Replacement: step 2, image 2 of 3 Toaster Oven Toasting Knob Replacement: step 2, image 3 of 3
    • Remove the four 4mm by 8mm screws from the black supports from the base of the toaster oven.
    • Take the two supports off of the bottom.
  3. Toaster Oven Toasting Knob Replacement: step 3, image 1 of 2 Toaster Oven Toasting Knob Replacement: step 3, image 2 of 2
    • Remove the two 4mm by 4mm screws from the base in order to remove the tray.
  4. Toaster Oven Toasting Knob Replacement: step 4, image 1 of 1
    • Slide the back panel off of the oven.
  5. Toaster Oven Toasting Knob Replacement: step 5, image 1 of 1
    • Grip the sides of the metal cover and lift the cover up off the toaster oven top.
  6. Toaster Oven Toasting Knob Replacement: step 6, image 1 of 3 Toaster Oven Toasting Knob Replacement: step 6, image 2 of 3 Toaster Oven Toasting Knob Replacement: step 6, image 3 of 3
    • The knob is missing in the first picture.
    • Push the knob into the hole.
    • The knob is now back in place in the last picture.
Alissa Mell
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 1,888
