Toaster magnetic switch repair
  1. Toaster magnetic switch repair, Magnetic Switch: step 1, image 1 of 2 Toaster magnetic switch repair, Magnetic Switch: step 1, image 2 of 2
    • Remove five screws, but the screws at the top left and right are special screws. I was able to loosen them with needle-nosed pliers and some fumbling and replaced them with Phillips screws
    • The second picture shows the very repair-unfriendly screw. Thank you Phillips!
  2. Toaster magnetic switch repair, Detach side panel and cover: step 2, image 1 of 2 Toaster magnetic switch repair, Detach side panel and cover: step 2, image 2 of 2
    • The side wall can now be opened and removed together with the cover.
    • Do this carefully. I broke the cover
    • The control electronics are housed on the side wall and attached to the magnetic switch with a plug connection. The plug connection has to be loosened (in my case it almost came off by itself)
  3. Toaster magnetic switch repair, Remove magnetic switch: step 3, image 1 of 2 Toaster magnetic switch repair, Remove magnetic switch: step 3, image 2 of 2
    • The arrow points to the plug connection to the control electronics. When assembling, reattach accordingly
    • The magnetic switch is held in place by a clamp that is bolted to the bottom of the toaster (see second image).
    • I had toast crumbs between the magnets and the anchor, which prevented them from working properly. I removed/scraped off these crumbs.
    • Then reassemble in reverse order.
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Ingmar
136 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 78
All Time: 3,157
