Toastmaster TMHP2 Disassembly
  1. Toastmaster TMHP2 Disassembly, Toastmaster TMHP2 Disassembly: step 1, image 1 of 1
    • Remove the lid and flip the pot over.
  2. Toastmaster TMHP2 Disassembly: step 2, image 1 of 2 Toastmaster TMHP2 Disassembly: step 2, image 2 of 2
    • Use the plastic opening tool to remove the three rubber feet.
  3. Toastmaster TMHP2 Disassembly: step 3, image 1 of 2 Toastmaster TMHP2 Disassembly: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the three 11 mm screws from the bottom of the device.
  4. Toastmaster TMHP2 Disassembly: step 4, image 1 of 2 Toastmaster TMHP2 Disassembly: step 4, image 2 of 2
    • Lift up the bottom cover to expose the internal wiring and components.
  5. Toastmaster TMHP2 Disassembly: step 5, image 1 of 3 Toastmaster TMHP2 Disassembly: step 5, image 2 of 3 Toastmaster TMHP2 Disassembly: step 5, image 3 of 3
    • Using the Phillips #1 screwdriver, remove the two 8 mm screws securing the thermal switch.
    • Remove the bracket securing the thermal switch from the device.
  6. Toastmaster TMHP2 Disassembly: step 6, image 1 of 3 Toastmaster TMHP2 Disassembly: step 6, image 2 of 3 Toastmaster TMHP2 Disassembly: step 6, image 3 of 3
    • Congratulations! You have disassembled the hot pot and can now see its internal compnents.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 272
